98240 wrote:is 55mm around 2inches is that alot of fender rolling
Um, no.
First off, your stock s14 rims are sunk like a ship, so you don't need to pull 2".
At about 1 degree camber, the rim will stick out approx 1/2"-1". at 2 degrees camber, should be very close to flush w/ just a roll and pull (as result of the rolling, so not very much pull).
That is x9 +17
You can't go much higher offset than that - x9+20 about as high as you want to go - to clear coilovers.
