17x8.5 +20 s13 in front need pulling?
toledo240
im considering the knockoff rota replicas of the ssr proffesors. He claims you need a slight pull for a +20 offset to fit the front. can anyone varify that? what about 8.5 with a +25 offset?what tires size do you guys recommend. 235 front and 255 rear?im running agx's and tein springs. thanks for the help
chmercer
what camber settings are you running. shouldnt need a pull if you have some camber.
why do you want to stagger the tires? the wheels are going to be the same size all around right..?
veilside180sx
Right now you have to preorder those rims, and they won't sell them in anything but staggered from what I've seen. They be bad if you could get all 8.5" width.
toledo240
yeah they got a gb now for 4 with +20 alll around
raging panda
Car: s13 coupe
a roll, not a pull, 17X9 +20 fit fine with just a roll, so yours will be even more sunk and will fit fine, maybe will stock fenders depending on your camber.
whiterps13
Car: white LE hatch
toledo240 wrote:yeah they got a gb now for 4 with +20 alll around
just curious, wheres the group buy?
toledo240
on zilvia.net if you need more info on them you can call the shop. they need 4 people to get them group buy
A Spec Products
Car: 240sx
toledo240 wrote:im considering the knockoff rota replicas of the ssr proffesors. He claims you need a slight pull for a +20 offset to fit the front. can anyone varify that? what about 8.5 with a +25 offset?what tires size do you guys recommend. 235 front and 255 rear?im running agx's and tein springs. thanks for the help
yes, like raging panda said, it will just need a roll
i sold couple sets of same size/offset 17x8.5+20 (Grenades) and it fit fine with a 215/45/17. not stretched, looks good, not sunk at all.
