17x8.5 +12 F 17x9.5 +13 R on S13 hatch?
ANVIL
Car: RB25DET S13.5
Wheel fitment noob here. I am looking at a set of 17x8.5 +12 F 17x9.5 +13 R for my s13 hatch. +20mm F fenders. Stock r fenders. Ideally i want to run a 275 or 265 tire in the rear. Would a 275/35 fit? Id run whatever tire would fit w/o mods in F. What mods would i need to do to fit?
You're not gonna fit that much under the rears.
I can't recall the exact specs on my setup, but I ran 275/40/17 under a VERY stretched rear fender on my S13 vert WITH bolt-on flares.
ANVIL
Car: RB25DET S13.5
appreciate the reply.
Basically i want to get a wider tire in the rear without adding over fenders and crazy camber.
What would you recommend? Is it the wheel specs that are preventing a 275 or is a 275 just too wide for stock body? Would that wheel work with a 255?
No, a 9.5" wheel is fine for that width (barely).
If there was an easy answer, everyone would simply copy that setup.
17x9.5 +12 is gonna be into the fender lip unless you do a roll/pull and run a stretched tire (235/40), or don't lower it much.
Stick to a less aggressive setup unless you really value looks over usefulness.
ANVIL
Car: RB25DET S13.5
Thank you. Looking for something with a higher offset now
LSDrift
Car: 1990 RS13 RB25
I'm planning on running one of those two widths on my hatch - currently have bought 275s to test fit width before I buy a wheel and it'll be a challenge if not impossible.
That being said - Broadfield has lots of experience with really wide tires on factory rear fenders (rolled and pulled in various stages) on his S13 --> https://broadfield.wordpress.com/catego ... ls-brakes/
"WedsSports TC-005’s 18×8.5 +32 245/40 and 18×10 +44 275/35 Very high ride height"
"Work Meister S1-2P’s 18×8 +32 235/40 and 18×9.5 +44 265/35. A little lower on Cusco Zero 2E coilovers."
"Work VS-KF’s 18×8 +21 225/40 and 18×10 +20 265/35. Lower again on modified Cusco Zero 2E’s and a 25mm rear pull"
"Work Meister S1-3P’s 18×9.5 +12 245/35 and 18×11 +30 285/30. Lower yet on Stance GR+ coilovers. +20mm ChargeSpeed wide front fenders and same 25mm pull"
