17x8 +35 on s13 front.......Whats the best spacer?
2-4-0
Car: 90 SR'd 240
My 17x8 +35 5zigens should be here soon. they'll be on the front of my s13
I just wanted to know what size spacer i should use for it to look best and will any rolling or anything be nescessary on the front? I'll have a 215/45/17 Tire
Also will there be any issues with running a 225/45/17 tire on a 17x9 and any rolling or anything for the rear?
Thanks-Ben
Modified by 2-4-0 at 9:42 PM 4/17/2006
nismofly
Car: 89 Nissan 240SX Hatch
what you *have* to run depends on tire size youre using
past that its personal preference
hannibal
Car: Red Line to Glenmont
The fronts should be fine with the 215/45 tire and no fender rolling.
nismofly
the fronts wont need any spacer with a 215, so youd just run a spacer to get it to look how you want
the rears you should run a 235/40/17 tire, a 225 isnt enough
2-4-0
Car: 90 SR'd 240
I've heard of people running a 225/45/17 on a 17x9 with no problem......
nismofly
but the stretch will be much more than if you ran a 215 front, if you want a 215/225 stagger run an 8.5 inch wide in the back
