17x8 +35 and 235/40/17
kamikazestorm420
is it possible to fit 235/40/17 on the front of a s13 with a +35 offset? will it have any rubbing issues on the strut cause i have 235/45/17 right now and it looks like a really tight fit
Ummm, they'll be the same.
You'll just reduce height.
I ran 255/40/17 on mine for 6 months with a 5mm spacer (same size / offset).
gumby74
A 235/40 will be a square to bulging sidewall you may want to run a spacer. I run a 225/45 on a 17x8 w +22. Perfect size all ways. Also I try to keep my tire diameters under 25" Cant remember my reasoning for that tho, but I am pretty sure I had a reason.
kamikazestorm420
so its possible to run 235/40's in the front?i know the overall diameter would be the same but i was wondering if it would hit the shocks or not.
whiterps13
Car: white LE hatch
Youre confused.
The sidewall on the 235/45 is going to be taller than a 235/40. The width will be the same, but the overall diameter of the tire will be less if you switch to a 235/40.
nismofly
Car: 89 Nissan 240SX Hatch
itll clear now, but if you ever got coilovers it wouldnt
whiterps13
Car: white LE hatch
nismofly wrote:itll clear now, but if you ever got coilovers it wouldnt
Just to clarify, your current tire size wont either.
nismofly
yeah, that too
to fit coilovers with that size youll need 215/45/17, for future reference
kamikazestorm420
blah, i must've have been drunk when i made that post. i meant i have 215/45/17's on my car right now (17x8 +35).
i am planning on getting 17x9 +20 and run 235/40/17 series on front and rear and was wondering if there would be any rubbing issues or any modifications such as rolling the fenders, etc. i am lowered on tein stech and kyb agx btw.
sorry for the confusion ...
nismofly
roll your fenders, probably a small pull so you can run around -2 front -1.7ish rear camber specs
you might not even need the pull with springs, but better to get it overwith if you ever get coilovers
kamikazestorm420
nismofly wrote:roll your fenders, probably a small pull so you can run around -2 front -1.7ish rear camber specs
thanks for the info
94_240sx
Car: 94_240SX
It depends on coilovers I guess. Mine cleared with no problems.235/40 RT-615s on 17x8 +38 wheels.
