17x8 +35 all the way around
kamikazestorm420
i am going to get 17x8 all the way around with 205/45/17F 225/45/17Rand i was wondering if megan racing coilovers would clear just fine?
how about the stock oem 7spokes? will those clear just fine?
thanks
veilside180sx
that size rims, run 215/45 and 235/40 F/R for tires.
szh
Car: 2018 Tesla Model 3.
Yes! 205/45-17 is too narrow for an 8" rim width - the recommended rim width range is 6.5"-7.5" for that tire width.
So, 215/45-17 is the minimum tire width I would use for that wheel. But, I do not know if this wheel and tire would fit on your car or not - I am merely commenting on the tire-to-wheel issue.
Z
veilside180sx
The sizes I mentioned are what I currently run on mine.
szh
veilside180sx wrote:The sizes I mentioned are what I currently run on mine.
Good. In case it is not clear, I was agreeing with your earlier post about the sizes! I just did not know about specific car fitment - thanks for clearing that up.
Z
nismofly
Car: 89 Nissan 240SX Hatch
i would personally run 235/40s all around...but thats just me
kamikazestorm420
would they clear coilovers?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
THey should.....
TurboKA37
i run 235/40 all around on my 17X8s i dont know why you would want to stagger the tire size, it will just remove the ability to rotate the tires. not sure about the coilover fitment tho
turtl631
Car: S14
Front coilover clearance will depend on the brand of coilover. Some have more than others, so its hard to say. Generally you want less than ET30 for a 8j wheel, so you'll be cutting it very close. I don't see why you want to stretch skinny tires on relatively narrow sunken wheels though. If you're into the "drift" look, just get 17x9 +20 all around and stretch tires. If you want properly sized tires for grip driving, get similar sized wheels with at least a 225/45 on front. Maybe get those 17x8 +35 and some spacers? That's not really a great size for anything, you might be better off with different wheels. I'm assuming you're talking about FNs
szh
Hi, turtl631.
If the correct offset is +20 for this car, then I agree! Like you said, the original poster should get the right wheel instead. While they are commonly used, spacers often cause more problems than they solve - structural integrity, balance, etc.
If a 17x8 +20 is the right size wheel, then buy it, rather than a 17x8 +35 with a 15mm spacer to try to get the same effective offset result.
Z
nismofly
if you were 5 lug 17 x 8 + 25 would be better
but i dont think you are, correct?
kamikazestorm420
nismofly wrote:if you were 5 lug 17 x 8 + 25 would be better
ya im still 4 lug.
turtl631 wrote:If you want properly sized tires for grip driving, get similar sized wheels with at least a 225/45 on front. I'm assuming you're talking about FNs
ya im more into grip driving then drifting. so you think i should run 225/45s all the way around? or stagger it?
and yes i am talking about the FNs
sry for all the questions -.-
SmithSR
Car: 240sx
215/45-17 on 17x8 +35 will clear your coilovers perfectly.215/45-17 is the correct overall diameter to match your OEM gear ratio.225/45-17 on 17x8 +35 will not clear your coilovers. (front)A proper package is tucked, even if only a little.Leave stretching and flush fads to our friends down south..
SmithSR
Car: 240sx
YAHTZEE!!
veilside180sx
My old hatch previous to accident with the aforementioned tire/wheel combo
kamikazestorm420
so i will be getting 215/45/17F 235/45/17R
and those will clear the MR coilovers correct?
SmithSR
Car: 240sx
Why such a massive rear tire?215/45-17 is the same diameter as stock.A 235/45-17 will actually slow your acceleration because taller tires change what is called the effective axle ratio.If you MUST do wider in rear, consider a 40-series to give you closer to OEM diameter, and help keep some of your torque.
kamikazestorm420
so you think i should just run 215/45/17 all the way around?
whiterps13
Car: white LE hatch
kamikazestorm420 wrote:so you think i should just run 215/45/17 all the way around?
yes. it will work fine, and the benefit of rotating tires is so underrated.
kamikazestorm420
ok thanks for all your help
grimple1
Car: 95 240sx Zenki
turtl631 wrote:Front coilover clearance will depend on the brand of coilover.
this is very true. the 5zigen +35 17x8's need a 5mm spacer with the KTS coilovers.
kamikazestorm420
do you thikn they would clear the megan racing coilovers?
SmithSR
Car: 240sx
It has more to do with the collar placement (how low your car is) than brand.If you must have the would-be jdm scraping on everything look, then you will have fitment problems.The coilovers are actually designed to allow clearance for nearly every modern wheel design. Dumping the car to the ground is the limiting factor.
8" +35 FN8"+30 rays
In the first picture, a 215/45-17 tucks under the collar very nicely and is the best all around hassle free, everyday driver kind of fitment.In the second picture, the +5 extra gives plenty of room for wider tires.
Most coils are the same diameter. In the years I've been on here and other sites, I still haven't seen anybody put up a confirmed list of coil diameters.
