Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Wed Dec 17, 2003 7:03 am
its nopt so much that the rear wheels are staitionary, its that you have more clearance form inner lip to-damper in the rear than the front, just take a look for yourself under you car..
when I say "Scrub" it means the inner edge of the tire will hit the outer edge of the damper on the front(or rear, if they're relaly dumb and picked a messed up offset)/
also, coilover diameter actually depends on manufacturere, some are 40mm, others 45, and still others even 50mm...
-chet
