i dont necessarily want stretch, but i dont want to run camber, and i dont want to rub the QPEnjoiNismo wrote:Depends if you want stretch or not. If it were me, Id get 205 or 215 max.
95zenki man wrote:Anything from a 215 ( bit of a stretch but not to bad) up to a 245 would be fine on 17x8.
That's it!! My wheels are 17x8 +23 and I have those tires. I put 245/40 in the front and tires were hitting fender liner which I still have. 235/40 is max you can put in the front. I used to have 235/40 in the rear, but switched to 245/40. 245/40 looks much better if you care about that. I rolled my rear fenders though.purestock240 wrote:i was thinking 235/40 front and 245/40 back but wanted others input.
my quarters are rolled, but even the 235/45 rubbed due to the wider subframe. im kind kicking myself now for thinking it would be cool to have an s14 subframe in the car94_240sx wrote:That's it!! My wheels are 17x8 +23 and I have those tires. I put 245/40 in the front and tires were hitting fender liner which I still have. 235/40 is max you can put in the front. I used to have 235/40 in the rear, but switched to 245/40. 245/40 looks much better if you care about that. I rolled my rear fenders though.purestock240 wrote:i was thinking 235/40 front and 245/40 back but wanted others input.
