Eddie »
https://forums.nicoclub.com/eddie-u12286.html
Mon Mar 01, 2004 4:32 am
A 7 in wide rim is equal to 177.8 mm.
225mm - 177.8mm = 47.2mm
47.2mm * (1 cm/10mm) * (1 in./2.54cm)= 1.86in. (approx.). Divide by 2 and that is roughly how much the tire will stick out on each side of the rim. With a 225 section width it will bulge out Approx. .93 in. (15/16 in.)
With a 255 section width approx. 1.5 in. will bulge out.
Sorry to get all technical, but hopefully it help you visualize it.
I run 225/50/16 on 6.5 width and car rides fine. 225 on a 7 width should do even better.
