17x10 +35 s13 rears
Mastaflash
Car: cars
im trying to find out if these will fit or not. i have a guy that is trying to get me to buy them, but im not sure if they will clear the coilovers. im looking for any info. if you have sizes similar please LMK.
crash n burn
Car: '91 Nissan LE hatch
'93 Nissan Silvia UDSM
'92 Infiniti M30
youd need to space that **** out to clear coils..10 is quite a bit of meat
how much he want?
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
Besides clearing the coilovers have you thought about clearing your rear fenders? If your fenders aren't rolled, and your car is lowered I can't see clearing both.
If some guy is trying to get you to buy them, what's the harm in asking to test fit them on your car?
180fan
Car: 89 fastback
I'm gonna move this thread to the wheels and tire section. Those guys will be able to tell you faster and probably more for sure.
Mastaflash
Car: cars
thanks for the move. i cant test fit because it isnt local. i have thought abouit fender clearance also, but i can roll the fenders for that. if it hits the coilover theres not much i can do. i would like to fit it with a roll, and no pull, or a very slight pull if anything.
i might just get them and resell the rears if they give me problems.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Good luck... mine are 17x9.5's on the rear with a +22 offset (look at the pics from the link in my sig if you want to see what it looks like)
You'll only be 7mm inside my setup on the outside and 19mm (~3/4") closer to the coilover than I am... I wouldn't do it if I were you
Mastaflash
Car: cars
well how much clearance do you have between your wheels and the coilover?
if they are more sunk in than yours it would work beter for me. im not going to pull my fenders the way you did.
rbsileighty
I have hicas so that is my inside limitation (have a new subframe to get rid of that though...)
Looks like you'd probably have room for 19mm inside mine.I'm pretty sure you'll still have to pull with only 7mm less sticking out than mine, as mine is a very aggressive pull.
Modified by rbsileighty at 11:39 AM 12/9/2006
Mastaflash
Car: cars
thanks for the pics. i think im just going to get them and get them to fit one way or another. spacers, roll, pull. ill get it on there one way or another.
rbsileighty
Anytime... I know how it was when I was looking for what I was going to use... not a lot out there with big sizes and low offsets (at least not to many that post)
What wheels are they? I'd recommend trying to get a little better offset so you're not using such a big spacer (if it turns out you need it)... FN01R's tend to have a nice selection of offsets and widths for a good price
Mastaflash
Car: cars
they are actully fn's. theres a guy selling a set, fronts have tires, for under 700 shipped, new.
if i were going to buy then id get a little lower offset.
Broadfield
Car: 1992 240sx
I run a 18 x 10 +44 on my coupe with a 275 tire. The fender is rolled, but that is it. No rubbing, no pulling. I have Buddy Club Race Spec coilovers and the inside of the wheel has about 20mm of clearance from the coil.
I will include a side pic to give you an idea of ride height...
rbsileighty
Broadfield wrote:I run a 18 x 10 +44 on my coupe with a 275 tire. The fender is rolled, but that is it. No rubbing, no pulling. I have Buddy Club Race Spec coilovers and the inside of the wheel has about 20mm of clearance from the coil.
Rear looks deeper than a +44... but of course I believe you... car looks great! Those stoptech's with Z32's on the back?
Broadfield
Car: 1992 240sx
rbsileighty wrote:Rear looks deeper than a +44... but of course I believe you... car looks great! Those stoptech's with Z32's on the back?
Yes sir, you are right on the money!.... Stoptechs and Z32's
Yeah, +44 in the rear. The front is a 8.5 +35
rbsileighty
Cool cool... yeah I love my stoptechs and been going back and forth on if I'll do Z32 rears or not, but no need to hijack the thread...
Sounds like those 10's +35 will fit with a minor roll and pull
Mastaflash
Car: cars
well i ended up not getting the wheels. took too long to decide and they got sold.
275! i didnt think it was possible. i guess there just arent enough people out there to tryo to run big sizes. id love to run 275s in the rear, and on stock body would be SEX! your car is great.
have any rear pics? id like to see how amazing those wide *** tires look from behind.
hannibal
Car: Red Line to Glenmont
Broadfield, your coupe looks great! Are those WedSport wheels?
onosqv
Car: '92 240sx Vert
Wow, 8.5 +35 in front clears coilovers? nice!
Broadfield
Car: 1992 240sx
I will have to take some pics from the rear once it is nice out.
Yes, they are Wedsports
The fronts clear the coilover by about 1.5mm!!! It virtually looks like it's touching!
Thanks for the comments.
