dash »
https://forums.nicoclub.com/dash-u40408.html
Tue Oct 17, 2006 2:54 am
doubt you'd see 330-350 atw from a s60 @17psi. A peep at miata dynos will tell ya for sure, as its a popular turbo for the d.i.y. crew.
The condition of your ca18 and quality of tune will tell what the motor will endure. Rod bearings go out on bone stock motors often...yet, seen unopened CAs stand up to 24psi and ~400hp. Broad spectrum.
I've 'heard' it say that, when you hear audible detonation, most likely its too late. Some "tuners" invest in apparatus (headphones?) to detect early signs of det, if you have no way of monitoring knock electronically like the cheap dsm dataloggers etc.Perhaps worth considering if you plan on 'pushing' your setup and tuning skills further.Checked your EGTs with the timing retarded further ? Probably rob you of torque if pulled back too much also.
Enlightening to see a nico member having success with d.i.y. rom tuning. You could be our resident Dr Drift or Horsham now rising from the ashes. hehehHurry up will ya... so u can burn ours too
Seriously tho, good effort, good luck. Car really scoots now, I bet
