What mods were done to that car to get those #'s above? your car or another car?Bigvinnie wrote:
Eh, you're the one who needs to do some reasearch.SonyPete wrote:Your right, displacement doens't matter, STROKE DOES. A engine that has a longer stroke needs longer duration due to the piston still coming down and being able to pull in air unlike a shorter stroke engine. Also depeneding on rod to stroke ratio you have a longer or shorter dwell time of the pistons at TDC and BDC which affects what is needed in terms of duration. So how about you go do a little of that stuff hmm what is it called, ohh yea "RESEARCH"
It's good to know that there are smart people in this forum......InsanityInc wrote:
A longer stroke engine has no special requirements as compared to a shorter stroke engine. You're confused. Rod to stroke ratio is what matters. An engine with a 200mm stroke and a 1.8:1 R:S will have the exact same piston motion as an engine with a 20mm stroke and a 1.8:1 R:S. And if I had to guess, I'd guess the R:S ratio between the CA16 and the KA24 are quite similar. Nissan seems to use about 1.7:1 on most of their passenger car engines from that era.
Also, regardless of what your R:S is, the same basic concepts still hold true. A later intake close will improve top end and reduce bottom end. More overlap will help the midrange.
SonyPete wrote:A engine that has a longer stroke needs longer duration due to the piston still coming down and being able to pull in air unlike a shorter stroke engine.
Geee well if anything the KA should use a shorter duration after what you just said. Since the upward piston momentum of the KA travels at about 5000FT per minute. It's all linear in rotation you speak of dwell time as if time literally stops for a piston and the crank, that isn't how it works, a crank is ALWAYS spinning then when the degree in the crank and distrubutor are met then the cylinder reaches detonation.....Again simple laws apply such as ignition timing to position of the crank.....Insanity hit it dead on the button with the ratio's in comparison....SonyPete wrote: Also depeneding on rod to stroke ratio you have a longer or shorter dwell time of the pistons at TDC and BDC which affects what is needed in terms of duration. So how about you go do a little of that stuff hmm what is it called, ohh yea "RESEARCH"
Well a bucket hydraulic assembly atleast for nissan is all the same and is bound to a certain lift and duration that no matter what cannot be exceeded, of course without major modification... You missed what I was implying. But whatever, this arguement is stupid and CA cam specs are usable.........SonyPete wrote:The CA and KA having same interchangable valve train parts has no relavancy what so ever to being able to use simliar cam specs. Hey they might both use simliar cam specs but that is based on a whole lotta other variables then similiar components or even stroke.
That isn't my car that is Scotts car. I found it in yahoo geocities.Here is his web site. Only thing that sucks is that Jim Wolfe doesn't offer this tune anymore. I'm suggesting that you get a bikirom or a standalone of some sort so that you can make those numbers on the dyno yourself....Heres the link with an impressive 1/4mile time and cheap mods.http://www.geocities.com/wssnider/240sxDYNO.htmlbrokeAs240sx wrote:
Try a launch diagnostic it will tell you if some of your equipment isn't functioning correctly. I can never answer those questions without driving the car or checking the engine, I just don't know.ivanqz wrote:Hey Bigvinnie, After reading your posts, I am starting to think that there is something wrong witth my 240 because It really just stops pulling after 5000 rpm. It is 92 bone stock with 103k miles. I do show 178 compresson on all cylindres. Is this normal for a bone stock KA? What mods do you have done to yours? Dynoed yet? I am going to get a base dyno run in a week or so. $70 for 3 runs. I'll post them as soon as I get them. Thanks
where is this tutorial? I can't seem to find it.TrueSlide wrote:BigV has a good writeup on club240 on making power with a KA N/A for cheap. Will be alittle more cause the CAMS he wrote it for at the time are like gone. So expensive cams are all that exist now. But cheaper then your price tag you got there.
It's not really a tutorial, just away to show a method of making power, since most people say that the KA can't yeild upto 200HP at the fly wheel with few mods. Yeah it's all good I used that same dyno to represnt that good power can still be made with the KA.Graphfixz wrote:
http://www.club240.com/forums/...30440
REally that what displacement means *smacks head* I SIMPLY stating that stroke had more of an effect and bore was very negligblebigvinnie wrote:OK so now you just made an a$$ of yourself like an OXIMORON. BORE X STROKE= displacement.
Wrong pulse width is based on engine specs such as cam and intake setup not hte other way around. Injector pulse width are figured out pretty much towrds the end of the engine creation.bigvinnie wrote:The constant variable that make lift and duration change are fuel dumping of what is pulse width of injection.
All that you posted is very basic knowledge and does nothing to disprove my prior statements, don't even know why you posted all of it. Hmm maybe just so people reading it would see you spewing out common knowledge that is TRUE that it makes you look like all your previous points were factual also.bigvinnie wrote: At 270cc injection the KA is bound to certain measurements that make up it's lift and duration. Too much lift or duration can contribute to too lean of a mixture there fore not making the engine streetable for smog emissions on the stock injection. Too much duration can also cause a non streetable car and a screwed idle. If you havent noticed there are 3 reasons why the KA lacks major power after 5900RPM. First the crank is half weighted and deals with harmonic stresses that kill power as RPM's increase. Secondly the cams are anemic that the KA no longer can breath and make power to it's injection meaning we already all know that the duration is too short ( but then again you don't see PDM or JWT increasing the duration too much either do ya buddy). If the duration becomes to long to make what you want as power in the higher rpm range the KA will lose it's smooth streetable idle.Third problem is that upward momentum and weight of rods and pistons is just to much for the valve train as RPM's increase closer to redline.
Good if you don't like it then leave. Nissan has followed the same stroker dynamic and geometry, it really hasn't changed up until the SR, so all you need to do is apply what valve train went to what engine and use those specs( like L is to Z as is to CAE as is to KAE, as CADE is to KADE), (I just spoon feed you as well as 300 other people with that info). If you knew your damn history on Nissan and 4 bangers you would of known what was compatible with what. Fact is I'm right and you are wrong so appoligize like any civilized adult. You started the arguement like a child without knowing what the frick you were talking about...Nissan history 101 b*tch.......SonyPete wrote:And you hate how people come in making statements about not knowing what the heck there talking about. Please spare me the words cause I hate Mr. Know it alls like your self that like to jump down peoples throats when ever they think their knowledge is all mighty. So thank YOU for showing all the young ones how NOT to act in a public place such as this.
You suck at life... Stop posting.....SonyPete wrote:
LOL like I stated before Mr. Shove it down everyone throat. I never started any of this negative conatone that you started and have set this thread as. And for the papers you have yet to disprove ANYTHING I have posted.
Yea the engines might respond to simliar cam specs but not because they share simliar valve train parts.
why would 3 inch be too big for NA? V8s run 3inch and bigger and lots of them are na. We also are NOT dealing with a 1.8 honda motor, the KA is alittle bigger.new_to_drift wrote:wont a 3" exhaust be too big? ive heard that the most you would want to go on a NA motor is 2.75.If you go too big you wont get enough back pressure which would in turn make you lose horsepower.Correct me if im wrong please.But ive just heard that 3 is too big.
Well said!BadMojo wrote:It would suck if this thread got locked. Lots of good info in this thread and the forum in general. I think the NA KA forum is a hidden gem and really deserves more traffic.
Can't we just keep it civil so the mods don't start locking stuff in here? I've learned quite a bit from reading these forums but stuff like this is really counterproductive.
