17 x 8 +35 all four corners S13?
swappedcrx
Car: building street cars for me and my band of misfits
any one think this'll have a problem with some 225/45 azenias?
Tires are a tiny bit taller (.3) than stock, but should fit fine.
Nismo_Freak
Car: 89 Nissan 240SX
AZhitman wrote:Tires are a tiny bit taller (.3) than stock, but should fit fine.
Look at this guy :D
240 fitment commando, welcome to the platoon.
I had to learn aspect ratios and OD's at a VERY young age... :)
swappedcrx
thanks guys do you think that offset will upset the handling or balance of the car in a bad way?
swappedcrx
mind you guys this is with the agx/eibach combo just want to make sure before i order these rims thanks in advance
Nismo_Freak
AZhitman wrote::)
Must be all those chariot wheels you replaced :D
Nismo_Freak
swappedcrx wrote:thanks guys do you think that offset will upset the handling or balance of the car in a bad way?
Even offsets/widths won't change the dynamics of the handling.
I disagree (somewhat).
Altering the TRACK of the car, whether via offset, wheel width, or a combination of both, can affect handling.
Obviously, a wider track is preferred, but keep in mind that extreme increases can increase loads on suspension components and lead to premature failure.
Nismo_Freak
AZhitman wrote:I disagree (somewhat).
Equal track won't induce understeer or oversteer was my point
veilside180sx
well that's the same size i'm running...but a 225 wouldn't clear up front...at least with my coilovers. They might with stock shocks. I can get my finger tip through between the top of the tire and the coils.
Paul_Ward
http://nicoclub.com/zerothread?id=77726
agx shocks with suspension tech springs.
cosmo
swappedcrx wrote: azenias?
Azenis
swappedcrx
Azenis thanks for clearing that up im sure nobody knew what i was talking about
