nismofly wrote:if youve already got the front fenders you need to roll the rears, otherwise youll never be able to match fitments
how wide are the front fenders? 20mm? if thats the case there arent spacers big enough to make that sit right...you shouldve gotten stock fenders for the front
i don't expect it to sit right b/c of the front fenders but i just don't want my rims to sink into my wheel wells. yes they are 20mm in front, but eventually i will put wider rear fenders on but now i just want these wheels to sit semi flush.
on a side note, why would you want bigger spacers in the front then the rear??don't you want the rears to sit further out then the fronts on RWD especailly on staggard wheels??
