17 x 7.5 on a S13
Mr. Joshua
Car: S13 hatch, AP1 S2000
Will a set of 5Zigen Copse wheels size 17 x 7.5 +43 offset with 205/40/17 series tires fit my S13 hatch with D2 coils?
SmithSR
Car: 240sx
+43 is a honda offset
Mr. Joshua
Yeah, I thought so, the guy selling them drives an 02 Civic. The only other offset they are available in is +35, would this work with spacers?
Exar-Kun
Car: 2005 350Z
I got 17x7.5" 30mm gram lights, its a perfect offset for the car. 5zigen wheels are heavy....I dislike them, except the FN series.-chet
SmithSR
Car: 240sx
With 15x7 +30 and GR6 coilovers I have less than 10mm clearance on front
BuudWeizErr
20mm spacers!
VitaminT
Car: 93 240sx SE
I have 17x7.5+30 in the front of my S13 with D2 coils and they have about a fingers width between the tire/rim and coilover. I guess that would be about 15mm. Oh and they are pretty flush too.
BuudWeizErr
coilover clearance also has to do with camber. I'm assuming you have little to no camber. the more camber you run, the lower your offset has to be to clear the coilover.
VitaminT
Car: 93 240sx SE
How is that so. In the rear I can see that, but if I adjust the front camber plates the coilover and rim both lean in. The distance between the coilover and rim does not change. Now if you use the adjustment/slot on the spindle bolt then I can see your point.
BuudWeizErr
most coilovers have two ways of adjusting camber. The first, obvious one is the camber plate, but the upper hole on the lower mounting bracket will be ovaled out... this is where you adjust camber without camber plates, and if you adjust it there, the more camber you add, the less clearance you have between the coilover and the inner wheel lip.
VitaminT
Car: 93 240sx SE
I understand now. Yeah I left the oval holes in the lower mount as far positive as I could and then adjust with the uppers.
BuudWeizErr
hahaha, i went as far negative as i could. i probably have like 5 degrees of negative right now, i need an alignment, bad.
VitaminT
Car: 93 240sx SE
Haha...sweet!
