AZhitman wrote:They're put on with that 3M double-sided tape, super sticky.
What they are supposed to be using is a 3M product called VHB Tape - Believe it or not - this tape has been around over 20 years ! It is used to replace welds, screws, glues and rivets on a range of materials. The damn stuff is used to replace some welds (used to join truck body panel w/o rivets) if applied properly - and the viscoelastic properties of the foam are a real plus in the tire environment. You can get some small 1X3" pieces at some of the Home Depots and play with it - Incredible stuff ! - Great to have some around to play with, or for that CYA instance -
VHB stands for Very High Bond - Hell, the tag line from the 3M flacks is “Imagine your world without rivets, screws, and welding” Not shilling for ‘em, but I figured a group of mechanically inclined NICO type might get a kick out of a good product if it's new to them.
AZhitman wrote:However, they DO come off, as I can attest to.
I’d have to guess that the installers were a bit less then diligent in prepping the surface of the wheel or getting oil from their hands onto the tape before the weight/tape got applied. The properly applied stuff just lasts - means you cut through the material w/a knife and then scrape or chemically remove the residue to get it off -
As I said, the specs are amazing when used right - There are 9,600 lbs of mirrored ceiling overhead in Chicago’s Midway Airport that are held up w/just this stuff - various forms of it are just what the OEMs use on vehicles for a range of items from trim to ?
Modified by msscomm at 4:35 PM 9/6/2004
