17" wheel on s13 tire size question
White Comet
Car: fc, s13 and mazda6, Sierra
well the HRi tires that were on it when i got it are shot so i'm trying to replace them. the tires on it were 205/40R17 on Exel Ennio 17x7 rims. I'm trying to go 225 in teh back and 215 up front. the question i have is about the aspect ratio, is there a big difference between 40 series and 45 series. it had 40s on it and i just wanna make sure i dont go w/ something that would put the speedo out of whack, since it seemed fine w/ the 40s. the only problem i have is that i cant find any decent tires that arent crazy expensive in 225/40R17. would it be ok to go 225/45R17 and 215/45R17 or not? i pretty much just wanna know what series is correct to have teh speedo as accurate as possible w/ 17" rims? thank you
Vidra
215/45/17 alll around
White Comet
45 will be accurate for the speedo? why 215 and not wider?
Vidra
given that u have 17x7 rims and an unknown offset, I'm going to assume +40.... if u run anything larger than 215 its gonna rub against the coilovers (if u have them). And yes, a 215/45/17 is about as close as ur gonna get to the OEM tire diameter.
whiterps13
Car: white LE hatch
Vidra: Not true.
225/45/17 will clear rear coilovers on a 17x7 +42. BUT, it wont clear up front.
BTW, dont stagger tires on identical sized wheels. Run a 215/45/17 all the way around.
/thread
Vidra
I agree with White.... I was debating whether to add about clearing the rear jus fine but I figured he knew that (I guess you got me this time!). As well, I wasn't about to have my man staggering his tires either! Good Points made!
White Comet
the council has spoken, no staggered setup it is. its not coilovers though just lowering springs but i'm going to coilovers soon. i just want ed to get teh best traction patches i could cuz i'm gonna need it for my new turbo. thanks for your help
