17" tire size
Wakkolio
I have 17x7 wheels for my 93 240sx. I have seen 215/45 and also 225/40 on 17X7 rims. I am now looking for new tires and would like to go the widest possible. I think 225 might be pushing it, what do you guys think?
KSee777
225/45/17 will work for 17x7 ... BUT, depending on your offset, it may rub against your fender or your suspension
chillmieste
Car: 97 240sx KA-T
I used 225/45/17 but it rubbed a little while braking. Im not sure on the offset but im sure that was the problem
Jookmasta
would those tires fit on a rim with a 47mm offset?
Exar-Kun
Car: 2005 350Z
keep the offset 40mm or less bro(at a maximum), 40mm was stock, and when you widen a rim, you dont want it to rub, so reduce the offset...-chet
