Probably true. Personally, if you are going this quality, I would recommend a wheel with greater width so you can get a full size tire on it. Worth it for increased performance including extended wear.szhosain wrote:The Goodyear Eagle F1 GS-D3 is perhaps not as good as the Michelin Pilot PS2, but is better than the Pilot Sport and Pilot Sport AS. The Eagles are also substantially less expensive than the PS2.
I use the Goodyear Eagle 245/45-18 in a 100W rating and like them a lot. Their wet handling and braking is outstanding and dry handling and braking is very good to excellent.
Lasted just over 20k miles on my last set and I replaced with the same ... mostly because there was a special on them at Tire Rack - four tires cost (net including a $100 cash card rebate) about $734, including shipping. A heck of a deal!
The 245/45-17 ought to be lower cost too ... in both brands and models. Lots of available tires in that size. Please see my detailed spreadsheet posted here somewhere ...
Someday, I will try out the Michelin PS2 as well ...
Z
