17" Steel wheels. Will or Won't??
M35x06
Car: 2006 Infinity M35x
could someone please confirm if 17" Steel Wheels will or will not fit the 2006 M35x? I'd like to buy some soon if they will fit. thank you.
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
As long as the bolt pattern size and depth is correct, I don't see why not.
mitrals
Car: 2006 Infiniti M35X
They fit. I had winter tires from my 2004 Maxima which I kept and they fit just fine.
dlibson
Car: 2006 M35X
They clear the front brakes huh? I was looking today and it didn't look like they would clear...
svard75
Car: 06 M35x
17" steel wheels may work but why not play it safe and buy cheap alloys. I have cheap alloys with winter rubber and they clear.
M35x06
Believe me if money wasn't an issue I wouldn't be looking at Steel wheels in the first place, but having checked out alloys it's going to cost another $100 for a cheap set of alloys.
Mitrals: so you took steel wheels and tires from your 04 Maxima and put them on an 06+ M35? do you have any pictures possibly?
merlinq2
Car: 2007 Infiniti M35x
msvara wrote:17" steel wheels may work but why not play it safe and buy cheap alloys. I have cheap alloys with winter rubber and they clear.
MS Vara, noticed that you have alloys, do you run tpms sensors in the winter set up- I have installed aftermarket sensors and have found that the my bcm will not accept the sensors. Right now I have my winters on the car - these happen to have Nissan sensors in them and I cannot get the system to recognize the sensors.
I have a continuous flashing light- flashes every second or so- any ideas?
mitrals
M35x06 wrote:Believe me if money wasn't an issue I wouldn't be looking at Steel wheels in the first place, but having checked out alloys it's going to cost another $100 for a cheap set of alloys.
I will take a picture and send it to you. Its nothing out of the ordinary. 17 inch steel rims with hub caps and 225 55 17 tires. I might get G35 rims and put it on the car.
M35x06
Thank you. I appreciate that.
