all wheels or just the sportmax 962 ??eds13 wrote:DO NOT GET 7'S IN THE FRONT!!
they look like anis and people always have understeer problems with them
He means that staggering wheels with 7" width in the front and 9" wide in the rear will cause massive understeer issues. Too much of a bias. I run 7 front 8rear and I am fine. Also running two different widths of tires will cause the same issue (example: 215 front and 235 rear..or along those lines)Niloss wrote:
psssshhh no prob dudeeds13 wrote:thank you christine
what susp you running? Anytype of spacers??.. im thinking about running 17x9's all around.. just wondering if ima have issues with stock susp.. will it rubb and if it will stick out the fender wells..triplesixrivals240 wrote:here we go again...
with 18x8 and 18x9.5 (if my memory serves me correctly).
If that helps you out at all.
Just saw these on ebay and the ebay store had a disclaimer saying that if you have coil overs they might rub and its the 18x8.5...i have tein type HEkM wrote:
