17" rims S13?
platinum240sx
does anyone have 17s on there s13 any problems i will encounter and can someone plz post some pics!
eniety
Car: Information Technology, Nissan, Gaming
I have 17's on my s13. I will post pictures later today.
S13Drifter
I got 17" and i know this isn't a good pic but it is all i got. BTW my car is droped 2" as well
S13Drifter
I forgot to say i have 205/50/17 tires and have had no problems other than the studs have rusted alittle, but they would have with stock tires. If you though that you would have clearence problems you will not. Have Fun.
blink0r
Car: Turbo(s), making fun of Daunttless, naked girls, and guitar.
I have 17" rims on my bicycle. They look bling bling, but man is it hard to bunny hop!
ninjak84
Car: S13, Z32, Titan
check out my sig, they're 17" ADR's
Tino
Car: Raising Hell
damn i thought 2 inchers would be lower.
S13Drifter
It is low, very low. I wouldn't feel it would be any safer to go any lower because at some points it is only 3-4" from my car to the ground and i would like to be able to go over my driveway curb.
Gaelen
Does anyone have trouble with tire rub or is the turning radius increased when you change the size of the tire??
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
dude Gaelen, if i were you i'd kick your car out and drive the M roadster. w/ that Dinan blower, i bet i can't imagine how fast that is.
S13Drifter
Gaelen wrote:Does anyone have trouble with tire rub or is the turning radius increased when you change the size of the tire??
As i said before I have had no tire rub. I would think that turning radius would be the same becuase your tires arn't go farther right or left. You can turn faster, but that is just 'cause i put Yokahama's (spelling) on mine. I can tell you though i think i should have gotton more tread 'cause it is easy to lose tranction in rain or snow in chicago. The joy of RWD. But in the dry they kick ***. Good luck.
Zebrahead
Car: cars, basketball, girls, fishing
ninjak84 wrote:check out my sig, they're 17" ADR's
That picture is very very dark. You obviously put it through PS, so put it through one more time and brighten it up a bit.
Nick.
P.S. Nice puppy, is it real? lol.
1991240xs
What's a good size tire for 17 inch rims?
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
anyone have 17" up front and 18" out back. cause thats what i want to do.
Exar-Kun
Car: 2005 350Z
well..I got one question...WHY?I mean, its not like th wight distribution would necessitate two different sized rims....why do you want to do that?
plus, its harder to match tire sizes that way(overall diam.) and what sizes were you planning to run? a 265-36-18 and a 225-45-17?
-chet
SRJesse
Car: Cars, hockey (roller and ice)
I was planning on getting 17" ASA JS1 rims with Kumho tires. Probably 215's because that would be the least speedometer difference with that size.
paul_s13
On the S13 I think its the width of the rim that is more critical, I know someone with 19's on his S13.
As long as you get a 35mm offset you should be ok to fit Z32 calipers on without spacers, sadly I had to use spacers with my 17's.
SpeeDDrifT
Car: drive. drift. drive....um drift...SAFELY. k
17's with about a 2 1/4 inch drop. i have had the tire rub the fender.....but that is only under extreme driving conditions, drifting. otherwise no.
Night
Car: working on my car
SpeeDDrifT wrote:17's with about a 2 1/4 inch drop. i have had the tire rub the fender.....but that is only under extreme driving conditions, drifting. otherwise no.
what size tire you running i have a 2 in drop and 17s comming this friday but i dontknow what size tire to look in to
SpeeDDrifT
they are 205/40/17.....
southbayS13
anyone use 215/45/17? any rubbing probs w/this size?
eniety
I have 215/40/17. No problems here.
RageAgainstNate
If you read SCC's Techo Babble Section in the Sept. 2002 issue you will get a very insightful look as to how to pick rims for the S13. Well actually you will read to only have them say "forget it, a 17x7.5 with +43 offset fits the 300zx Brembo brakes...''
