Congrats, you've managed to peeve mee off. lets disct your argument for a second.
vq35de wrote:Ok, before I start my long a*s rant, he may be faster with a 215 series tire, due to friction and rolling mass. By going to 17" tires I don't think he is concerned with rotating mass or he has enough power in his goals to make up for it.
He will be faster wit a 215-45-17 because the tire is able to do its job better on a 7" wheel, not because of rolling resistance, since contact patch area does NOT vary by width...but we'll get to that later. Friction is characteristics due to the tire and road surface, and teh weight on the tire, not width(since contact patch doesnt get affected by width) Also, hes driving a 1992 240sx, which means you want the gearing low, since its not a top end car..going larger will ruin his gearing somewhat...now lets continue.
So 225/235 or even 245 series tires may be needed.
No, a sticky tires is neaded for high horsepower, just like I said, the compound of the tire is more important to the cars grip than the section width.
So here is my rant on 235's and 245's on a 17x7 rim:
ok, 235/50 is wonderful on a 17x7 rim, tread wear is great no problem at all. it is even in tirerack's recommended rim width for that tire. My point is it will be alot larger (1.6" larger than stock for a 240sx).
245's will not get the correct contact patch but will FIT. That is why I mentioned it. It will have more surface area than a 235 on the ground, it will not cause bead seating problems. It will put excess stress on the sidewall and will cause the tread to wear unevenly but 245/45's will fit. It is great for autocross, but not for street use.
so your telling me uneven tread stress is GOOD for autocross? I thought the object was to maximise grip, meaning maximise the contact patch available by putting it on the ground..uneven tread wear means just the opposite. And again, contact patch area is a function of vehicle weight and distribution more than the section width of the tire. Its physics. Also, I would wager you have never ran a slightly smaller tire in an autocross, because...if you did, and it WAS properly matched to the wheel, it does its job better, resulting in quicker laps times. Also, oversizing a wheel is NOT good for autcoross, for some reasons above, but more for safety..when do you think a tire is more liable to de-seat its own bead, at 99% lateral stress(racing) or at 70% stress when street driving...?
He asked for input. Don't dis the advice without knowing.
wow, I would totally take my own advice here.
235/50 and even 235/45's will fit on the 17x7 rim with ZERO problems on tread contact or bead. The 235/50 will have zero additional sidewall stress. The 235/45 will have some additional sidewall stress but that particular tire size comes with some world class tires that are made to handle the abuse.
Ok, a 235-45-17 is still a bit wide, due to its lower sidewall height. and when did the sidewlal of the tire being stiffer means that you can run a smaller wheel? its the other way around man. the stiffer the sidewall(lower hieght, thicker, higher bead stabilizers) the more carefully you have to match the wheel width to the tire for proper handling and performance. If you look at the MAST guide, lower profile tires have closer tollereances in rim ranges for a reason. The 235-50-17 works fine on a 7" wheel, like you said.
I have been using the 17x7 rim for 3 years now (stock size rim on 3.5 liter altima and G35 and I KNOW the tires that work on it. I have had 4 different brands on MY rims and have driven cars with many other brands/sizes)
great, I've driven many track days, road raced at road atlanta and while we're naming off cool things, driven a ferrari F40 around. STILL doesn't mean you know what your doing with wheels and tires. Michael Shumacher probably coouldnt tell you how to adjust air pressure, and properly select tires for a vehicle man. Yet, I'm glad you've expermineted with 4 different brands, thats great, please leave me some feedback on your impressions on each tire and how you thought it did.
I'll leave you with a few ideas:"just beause you CAN, doesn't mean you SHOULD" (dude I can fit a 255-40-17 on a 7" rim...)
and:"when you think you know everything, you know nothing."
so please, before you decide to start bashing mine, alan, grant, or smiths advice(much less michelin and pirelli and yokohamas engineeres sizing constraints) take your own advice:
"dont dis advice without knowing"
-chet
