Sentientbydesign wrote:As for the camber kit, Eibach recommends it. The 1.5 inch drop takes the car's camber out of spec. Which ranges from .5 positive to 1 negative.
At 1.5" it doesn't take it out of spec. I stayed and have been fully within spec since day 1. At 1.5" drop my camber settings are:
LF -0.4ºRF -0.8ºLR -1.2ºRR-1.1º
Factory specs 00-03 Maxima are as follows: CamberFRONT +0.5º to -1.0ºREAR -0.3º to -1.8º
Toe FRONT 0.00" to +0.05" REAR -0.07" to +0.11"
Steer ahead-.05º to +.05º
Thrust angle0.02º There is no range on this.
Caster (which is not adjustable unless you get coilovers)2.0º to 3.5º
At 2.25" yes you will fall out of spec.
