nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Sun Dec 07, 2008 12:19 pm
They "fill the wheel well" the same, assuming you run the right diameter tires. The only way to really reduce the open space in the wheel wells is to lower the car.
35 series tires are so thin that the likelihood of bending a wheel goes up and ride quality is reduced significantly. Of course, this is a matter of preference.
Mag, your 07 is a different generation. The design works with larger wheels better both aesthetically and in terms of tire size.
