1. I think theyll look great2. no3. no4. Yes, however its notbecause the tires are wider, its because they are better 5. obviously6. Shouldnt, i guess in theory they might but i doubt if youd actually be able to tell a difference7. I cannot predict thatlfootmatt wrote:What do you think of the price?
Elwesso,
1. Will they look stupid?
2. Will they rub?
3. Will they change the speedo much?
4. Do you think it would handle better with the wider tires?
5. And since you said they will fit, I assume the bolt pattern is the same.
6. And lastly, will they harm the already poor mileage or decrease braking ability with stock calipers on SP slotted rotors?
7. And most importantly, will the wife have a cow?!
Thanks, Matt
They do, however, its so little youd hardly notice..... Stock tire diameter is 26in. 245-45-18 have a 26.7 or so (actual OD depends on the tire brand). So at worst, figure the speedo will be off by about 3-4%, which youd never actually notice..... 4MPH at 100MPH.drape123 wrote:
hey elwesso, i thought bigger tires would most definately mess the speedo up, does it at all?
