cdlong wrote:i'm more concerned with the different setup of the hardlines and the connection on the bottom. i'm not sure what it is but i haven't really looked.
i doubt the booster will make a difference. but i'm just talking out of my ***.
You *** talker... hahaha
w/ the 17/16 mc in the front, you will still have brake imbalance, however, a little less than before since it has a higher break up point (sends more to the rear longer).
It will definitely make it feel stiffer - if you feel the current setup is too soft - that stiffness is sort of adjustable via the bolt/screw in the brake booster, but basically you have to bleed the brakes each adjustment: making the bolt "tight"/i.e. turn in, makes it softer.
Also, another reason to upgrade is that the normal mc will send much more pressure to the front brakes than the 17/16 mc will. However, keep in mind this mc was designed for the front & rear, not just the front & stock rear.
Anyway, I've only done this on my s13, so I'm not sure what you have to do on the s14. It's definitely stiff, but not omg it's ****in stiff, stiff. You get used to it after a week.
