the front was rubbing like crazy so i took it out and put donuts up front until i can find a way to fit without rubbing...its ONLY sportmax 002 with 0 offset...24j0hn wrote:what size tires are you rollin now?
sick *** rims, where u get them?
camber all the way..still stick out....i know a place in stockton to roll my fender..thanks buddies...so brbpandapants wrote:dial in some - camber.done.
I wouldn't go to Autosport Addiction or whatever it's called now, unless they have a roller. I already rolled mine up a little bit with a pipe, tshirt and heat gun. I took it to them to hopefully finish it up. All they did was cut slices into the fender lip and folded the lip back a bit more.i240sx wrote:
Modified by i240sx at 10:33 PM 1/30/2009
