16x8 rim on a b14??? any know if possible
speeddocsson
Car: 2006 NIssan Titan,1991 Infiniti M30 vert. TURBO,1969 Datsun 1600 roadster, 1975 Honda CB550 cafe
I am wondering if anybody knows if that is a possible fit. The car is lowered an inch and a half already. any ideas
nametakennow
Car: '06 MINI Cooper S
What's the offset and what size tire are you planning to run?
speeddocsson
Well I really want to try to run the xxr 002 rims. The offset is 0 and there is an option of either running a 205/45/16 or 205/40/16 tire...... There might be a possibility of running the 16x8 on the back and a 16x7 on the front any help would be great
speeddocsson
supposedly they can fit Scion xBMazda MiataAE86 Toyota Corolla GTS/SR5S13 Nissan 240SXBMW E30
if that helps
nametakennow
Okay, a few things.
1. +0 offset means the wheel will already stick out ~40something mm further than the stock wheels. Add to that fact that this wheel is a good 1.5in-2in wider than your stock ones, and you essentially have a wheel that is 3-4in further out than stock. In essence, unless you cut the fenders and put some seriously huge overfenders on, it's not going to fit.
2. Even if you did that, your suspension geometry would be all kinds of screwy, at least according to engineers I've talked to about the subject. It's something about the center of mass of the wheel vs. stock and strain on the hub assembly and so forth. It's over my head so I won't try to explain it. Long story short, there's the possibility that you'd have a terrible ride and maybe even wear out parts of your wheel and suspension assembly prematurely.
3. Staggered wheels only really make sense in two situations. Either it's a RWD car making fairly big power, so you put wider wheels in the back to put more rubber in the back for better traction, or it's a FWD car used exclusively for drag racing and you put wider wheels in front for better traction. I don't think either of those applies here.
4. 8in wide wheels with 205 series tires on them don't make a lot of sense. I know some people like the "stretched" tire look, but it doesn't make much functional sense. An 8in wide wheel should wear 225-245 series tires on it, generally.
I've been looking at 15 and 16X8's for my B15 (which has roughly the same amount of room in the fenders as your B14) for a good 2 years now. They more or less don't exist because the offset would absolutely have to be no lower than +35 and no higher than +40, and the former would require at least a little fender roll even with a 225 tire (which doesn't exist in the right height) on it. There are a few wheels that supposedly fit that description (for instance, I've seen websites listing Work Equip 03s that supposedly come in a 16X7.5 or 16X8 +38, but I haven't verified that and they're over $300 each, and I don't have $1200+tires+fender roll to throw around).
I've seen instances where people use camber plates/bolts to tuck wheels in, but that's awful for tire wear and suspension tuning (and, therein, handling).
I've also seen people run 16 or 17X8's with 245s on them and hope that they don't ever hit a low spot and destroy the fender and tire (or they have extremely stiff suspensions, not sure), but these definitely didn't have a 0 offset.
Anyway, enough rambling on my part.
16X7's are readily available and can easily handle the 205 tire you're looking at. XXR has some as does Rota, to name a few.
Any time I've seen them on those vehicles, they have fender work, especially the FWD ones. Just an FYI.
speeddocsson
That was what i figured..... I just figured i would ask im just gonna go with rotas i think thanks for the help.
nametakennow
It took me quite awhile to understand how offsets work and the kind of fender room the B13-15 Sentra/200SXs have. I figured I might as well write everything down for this post, even information you didn't really ask for, so that when people search they'll get a complete answer.
In fact, now that I think about it, I probably should have written this and some other wheel/suspension info up for an FAQ... hrrrmmm...
In other words, thanks for asking!
ABNRML4U
Car: Nissan B13
Do you still have that M30? I was trying to find some Info. on one B/C I saw a 92-93 M30 convertable thinking of getting one
85rx-7gsl-se
M30's are so hot. There is a white M30 Vert in the Memphis area I see every once in a while
ABNRML4U
Car: Nissan B13
Thanks Bro, I was looking at a Black one here in Tampa, FL I might test drive it one day Then I might not want to get out of it too.
speeddocsson
Yeah i still got it. Get one! they are great cars and they are starting to get a small following.
