Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Fri Oct 27, 2006 7:33 pm
It is a little small, and we do not know that it is smaller in capability than the T25, since a map was never released. Basically, I don't think you hit those power levels until almost 20, right? Can you use that? The T3 is tried and true, and with a .48, will work famously for fast spool. Also, the TD06-20g is the best bet for our motors (Came on the Typhoon/Syclone and is in the Greedy kit).Then again, I am running the T04b, and so I am one of those ***holes who doesn't listen. So if you are stuck on the 16g, and can make it happen, then good luck.
