dash »
https://forums.nicoclub.com/dash-u40408.html
Sat May 30, 2009 1:19 am
A 16G has proven a very good match for the CA18 and the DSM turbos are clocked perfectly for bottom mount..... that's about it.16 attached using long bolts thru the DSM manifold, nothing like the T25.
If the 16 can fit under the stock manifold, u can weld the turbine housing directly onto the CA manifold, as I've seen done lotsa times by some very experienced folks. The argument is, u can always find a cheap mani & DSM turbine housing if.... Best of all, you'll never have those common pesky turbo-to-manifold gasket leaks - lol
If you're bent on the 16, a custom manifold is the best route imo also
or sell the 16, buy a SR T25 or 28.
boost_boy offered perhaps the best bolt-on "hookups" around for the CA18 (new T28 core 'fitted' to your stock housing). Dunno if still available.
A few on SXOC r actually happy with their ebay/chinese T28... if ya feel lucky.
If u can't afford a turbo, what will u do for the "supporting mods" needed to "feed" a turbo the size of a 16G ??
