deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sun Feb 15, 2004 1:09 pm
you can get solid lifter converions from realnissan.com, tulsaturbo.com, and from me. Mine are lower profile, i use higher quality hardened parts, and they are lighter as well compared to the others (mine do not require valve cover modification btw..). You can get custom titanium retainers made up, but unless you plan on spinning 8500+rpm you will not benefit much. Springs for the sohc can be had in many combinations, some opt only to upgrade the exhaust springs (as valvespring rate/actual valve weight ratio is not as good as the intakes). This can be done very cheaply. Full custom springs i can have made for sohc, this gets a tad expensive, but you have more spring rate options
