evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Dec 30, 2011 10:54 am
first of all, "wheels" they are called "wheels" a "rim" is simply the outter edge fo a "wheel", sorry just a pet peave of mine
I'm guessing we are talking about your 84 300ZX which would apparently be an n/a with 4x4.5 lug patters, which has a limited selection fo wheels in the positive offset required, in whihc case, yes a 5 lug conversion is a good idea, not only that it's pretty simple using junk yard parts and you can even upgrade your brakes int he process
on the subject of tires, I don't knwo where you are shopping but 15's have a huge slection of performance oriented tires both in R compound and ultra high perfromance street tires, hankook rs3's are the topdog right not and they offer a 15 in tires, as for kumho XS, dunlop Direzza z1 star spec and countless others (you can thank the popularity of miata's in motorsports for assuring you'll have excellent 15 inch tire choices for years to come, that being said, get the 16's, the propper 15's have a lot of sidewall, great if you want to drive granny on sunday but if you like to carve corners you're gonna want a tire with less shoulder, and the 16's came form the factory on most of the turbo z31's, 18's are too big imho, the bigger the wheel the heavier it is and the more weight your anemic 160 hp v6 will have to turn, and with such a low aspect ratio your gonna feel every bump in the road and nto in a good way
