16" G35 wheels???
S14 boy
Car: 1997 nissan 240sx(R.I.P) 2003 VW GTI 1.8T 1975 Triumph TR6 Overdrive
really dumb question but..... does anyone know anything about the OEM 16x6.5 G35 wheels? they should be 5-lug, i need to know what the lug pattern is. if they are 5x114 then they should be able to fit on my '97 240SX SE, right?
thank you in advance!
Rex
Car: None
S14 boy wrote:really dumb question but..... does anyone know anything about the OEM 16x6.5 G35 wheels? they should be 5-lug, i need to know what the lug pattern is. if they are 5x114 then they should be able to fit on my '97 240SX SE, right?
Yes, they would be 5 lug and they would be "standard Nissan" OEM 5 lug pattern. I'm having a hard time recalling what the 16" ones looked like, but I've seen the 17's & 18's on an S14 and they looked good .
S14 boy
thanks alot! are these by chance the 16"?
Rex
Car: None
According to this ebay auction, those are the 17'shttp://cgi.ebay.com/ebaymotors...wItem
FWIW, I can't find a single 16" on ebay.
S14 boy
ok thanks, this is what i was looking at, and there is no pic. so, maybe i'll call the dealer or something http://www.wheelx.com/infiniti....html
thanks!!!
Rex
Car: None
Should fit, may be a little "tucked", but nothing too bad.
I'd suggest you check ebay for deals on the 17's with tires, unless you're getting a smoking deal on the 16's.
If you watch closely some deals can be had. I got my 350Z Track model 18" Rays with like new tires for <$800 shipped.
S14 boy
yeah, i'll def. look into it further, thanks alot!
Rex
Car: None
No Problem, always looking to help.
Here's the G35 coupe 18's on an S14
Exar-Kun
Car: 2005 350Z
Rex, your front tires are rotating the wrong direction it looks like by the side treadblocks..
-CHet
Rex
Car: None
Exar-Kun wrote:Rex, your front tires are rotating the wrong direction it looks like by the side treadblocks..
-CHet
LOL, that's not mine, it's 574-240sx's and I think he was just doing a "test fit" after buying them.
Good eye and Thanks for looking out for a brother.
