Juujai wrote:technically it wouldn't stick out an inch more. it's half inch towards shock clearance and half inch sticking outwards. 12mm~ like i said earlier.
-1 deg camber can flush in approx 5mm. so with 12mm more you'd have to do about 2.5deg neg camber in addition to what that x7+0 guy is doing. assuming you're balls out and don't mind eating tires and wanna look cool lol... pulling fenders can go over 20mm depending how much u wanna pull.
but that only matters if its really 4x114...
but yeah thats correct they will fit even if you don't touch any camber/fender mods... it'll just look low rider vato.
the wheels originally posted are 8.5" wide so it would be 3/4" from width, and 6mm from the lower offset, about 1/4", totaling around 1". but yes, x8 +0 would only give you 1/2".
short of some serious effort, they don't fit. (again, ignoring the bolt pattern issue)
