180sx Dreams wrote:so i got a 15x7 wheel and I was wondering what size tire can be installed onto it. And also i was wondering if anyone has a size wheel like that on their car and whether or not there is an awesome wheel/tire combo that can be done. thanks for the help!
Go with a 225-50-15 or 245-45-15 if you can--you will love the wider contact patch. Might depend on the offset of your rim. I run 225's on a 35mm rim and it just fits. Any higher you would be in trouble.
Also --different tires in the same size have different widths. Check the "specs" page of the tire at tire rack if you can.
BTW--I have been running 205/50/15's on a different set of rims (lower offset actually --free AXtires) --so I can make a pretty decent comparison between the two.
