ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Fri Sep 30, 2005 3:23 pm
Check and reset ignition timing. Check spark plug gaps. Move to 1 step colder spark plugs.
Sounds to me like you are experiencing ignition breakup or too rich to fire. If you truely ever experienced detonation, you do not actually "feel" it unless your body is full of robotic sensors. Often at times, you should hear pinging or preignition/knock. A missfire can be felt and is pretty common and is usually related to ignition system problems. Sometimes it can be related to too rich of a fuel mixture drowning the spark. Best thing to do is get a wideband on there to make sure you are not running lean. Too lean can often cause misses too but more in a bucking fashion in the lower rpm range. If your afr's check out, I would suggest looking into your ignition system. I've seen SR coilpacks do retarded things in my many experiences. The thing is, you can test them via FSM way, and they will still check out and seem sound (faking the funk?). Get a wideband on there to find out what's really happening.
