deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Fri Nov 03, 2006 2:09 pm
The highest load scale in Shawn's tune is not accessed with his current (or at least at time of tuning) setup.
The ecu configuration for Z32 and 460cc injector provided a maximum TP of 35 and a maximum duty cycle of 60% with his setup.
The file is tuned with headroom so that if Shawn wanted to change up his turbo and what not, add boost, he would be well within the limits of the ecus resolution and not limited to a necessary retune (provided the MAF and injectors are kept). The fuel correction is provided up to 4.9v MAFv and ~98% duty cycle.
Also, during tuning Shawns car was running just a bit on the hot side, I was with it long enough to confirm temperature stabilization after multiple runs, but it was still before the heat of the summer. I did pull the timing back just a tad on a revision I sent to him, because of this reason. It is actually tuned rather aggressively, timing wise. Full boost at 6000 rpm he is getting ~22 degrees advance, when the car is warmed up. Additional timing is provided when cold, and if his car were to ever get super hot (coolant or IAT), up to 6 degrees of timing would be subtracted.
When looking at the maps, remember his car is barely passing half the map, that should put things into better perspective.
Lowering the TP value on the TP scale does not necessarily reduce fuel correction. Fuel correction will only be affected if the correction value (cell value) is a lower value than was previously being plotted at that point. Modifying your TP scale changes plot characteristics, obviously, so by lowering say your last 5 values, the ecu will move past those columns much more quickly (reduced slope). Simple nature of the scales, this is how you shift your fuel table resolution, not how you correct fuel.
To correct fueling, use the table cell values.
