TrevorK »
https://forums.nicoclub.com/trevork-u192129.html
Tue Dec 15, 2015 10:47 am
I will start off by agreeing with everyone who will post and say "you can get it done cheaper at an independent shop". For example, most people are capable of changing out the in cabin filter, air filter and wiper blades themselves (and there should be youtube videos for these that specifically pertain to the Rogue). And rotating the tires is doable (but sometimes for the price it's easier to just pay the $20 and have them done at the dealer). The one piece that you and most independent shops cannot do is the CONSULT scan, which is a tool that Nissan has to read through all your sensors.
That said, one of the reasons the dealers love this work is because it can generate more work, and at your mileage, it will typically be under warranty so no cost to you. It is in their best interests to find things to fix, and in your interests as well because they should not come at a cost to you.
Overall - a lot of the work quoted is stuff you should do. You should: change your air filter, change your wiper blades (or at least make sure they aren't streaky), change your in cabin filter, top off your fluids, check your tire wear/depth, rotate your tires and change your oil/filter. Items like the CONSULT scan and charging system check are preventative items, to try and detect problems before they occur.
In regards to your brake problems, you would probably want to look at having your brakes inspected and serviced to maintain their proper operation. There is a video on here from a member for disassembling your brakes to lube the pins, clean them, etc. but I completely understand that is not something everyone is comfortable with.
