Truerocket11 wrote:I am going for output but if it can be done without sacrificing too much of my trunk I would be pretty satisfied. The box I have now was free including the subs so Im not complaining about that lol. I'm just planning on ripping out the middle of my backseat to install my current JL's in a plexiglass enclosure and putting a box with the two Oxygens in my trunk. Of course I'm probably going to need a better battery than the stock and a more poweful amp
I am no car audio expert by any means but I do know power and have a good background in physics and electronics. But I have been watching this thread for a while now and thought I would pitch in my engineers perspective on all this.. for what it's worth..lol
First: Holy sweet mother of god dude, that is going to be frickin loud.
Second: I am sure if you gutted your trunk, and took the back seats out you could probably make room for all that. If you are good at it or have someone who is you could probably custom build some huge fibreglass monster to house it all. I have seen some really crazy custom setups that actually look pretty professionally done. Prolly wont be cheap.
BUT let me tell you that you need to plan on some major power upgrades. Say you had 2000watts driving those 15's. Your cars electrical system is 12/14volts. so 2000watts divided by 14volts is 143amps. Now say maybe a 1000watts more for the JLs. 1000watts divided by 14volts is 71amps. That brings your total amps just for all those subs up to 214amps!. I think the stock alternator for the newer altis is something like 120 amps!
Plus your car needs to run all of its equipment... no idea what the ampere requirement is for that, but plan on buying a high amp alternator. Spendy im sure.
Next: grounding. Plan on upgrading all your grounding. I think they use #4awg wire as the stock ground. #4 wire is good for 95amps (NEC 2008). So for the 300-350 amps you need would need like 300Kcm wire or more feasibly a parallel run of 2/0.
You would also likely have to parallel a second battery back to your rig.
Lastly you would probably be running close to a pressure threshold. I dont have all of those formulas memorized, and i am to lazy to look them up and the cabin size of your alti and do all the math. But that amount or decibels and pressure in that small of a place you would no doubt have all kinds of rattles. You would probably start to develop more over time too. Also all of the seals in your windows and stuff could start to blow out and develop leaks.
Just something to keep in mind when you dream big, it usually costs big too. Again I could be wrong on all this and certainly Apple and these other pros would have more actual knowlege in this subject.
This is just strictly from my engineering perspective. But from the sounds of it, if you are going to do this you are going to need a fist full of cash, and a lot of time to do some modding work. If you get it up and running Im sure we would all love some pics of how you pull it off!
