To Nico !!
Try this diag and report back.
Transmission Self Diagnostics
Courtsey of Gerardjg
using AT light below your temperature gauge on the dash
1-Warm up engine
2- Shut off car and turn ignition switch to ACC position
3-Wait 5 seconds
4-Move shifter to D
5-Turn ignition switch on do not start
AT check light should come on for about 2 seconds
6-Move shifter to 3
7- step on gas fully and release
8-Move shifter to 2
9-Move shifter to 1
10-step on gas fully and release
The At Check light should start flashing 11 flashes a
slight pause and start over again. All flashes should
be the same length, any flash that is longer indicates a
trouble the following list is what the trouble circuit or part is.
A longer flash indicates
1st Flash Revolution sensor
2nd flash Speed sensor
3rd flash Throttle position sensor
4th Shift solenoid valve a
5th Shift solenoid valve b
6th overrun clutch solenoid
7th tourqe converter clutch solenoid
8th fluid temp sensor
9th engine speed signal
10th turbine revolution sensor
11th pressure solenoid valve
