zozoka1212 »
https://forums.nicoclub.com/zozoka1212-u59702.html
Thu Oct 22, 2009 5:31 am
When the car is running and it is in park. Hit the right top buttom (steering column) and check the dot matrix display till you get the option says skip,maint, bla bla than go with the buttom under and select the main than it gives you option for oil change/ tire others. select each and gives you option to reset it or delete it.
