Nissan-S14 wrote:By the way I have timing increased to 4-5 degrees, its been 2 years, not a single det. But I only use 93 octane.
i also only run 93 octane, i found that i started to loose power after 3 degrees, and there wasnt any gain between 2.5 and 3 so i left it at the safer 2.5.......... unless you know what your doing, dont do it just be safe and save ur engine............. detonation also has to do with intake inlet temprature, humidity and air density, so you could run 5degrees with out knock but im sure you know what ur doing.
what were your last compression test results?
