15" wheels on Z32 TT brakes???
A home for 1983–1989 300ZX owners!
TubedSR86
Car: SR20DET powered AE86 with IRS
My track car has Z32 brakes, and im a bit limited to wheel size. Would i be able to fit 15" straight spoked 15" wheels on my vehicle? Just asking incase someone else has done it before. Thanks, Matt
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Depends on spoke design. You need to check hub to spoke depth.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
yup depends ont the wheels, and you didn't specify what car the Z32 brakes are on, seeing as this si the classic z section I'd guess you either adapted to fit the z31 or bought the old kit from discovery parts to fir the s30, (guessing it's not the toyota under your name) I think on the s30 the caliper protrudes in front of the hub surface a bit, panasport, ccw, keizer and other manufacturers can make the wheel to fit your specs and have worksheets to fill out all the important measurements, and most 15" wheels do clear the rears on a Z32
Return to “300ZX (Z31) Forum”
