Chris92SE wrote: ↑Wed Jul 01, 2020 9:06 pm
It's not a huge difference, but I drive out into the woods and I prefer a little more sidewall flex and rubber between the wheel and the rocks.
This. I was seeking the same without getting a lift (which I will do later).
Problem is you need at least 3.75" of backspacing if you want to get taller tires (e.g. 31"). By getting a wheel with that backspacing, you open up more options in the tire choices.
I snagged a set of 4 of these for $200 recently
https://www.summitracing.com/parts/usw-046-5860gm
and will be trying on some Cooper Discoverers soon. Question is if I should do the 70 or 75 aspect ratio. (Is the poorer gas mileage worth the tradeoff of the extra half inch of sidewall)
OEM spec in Italics:
SPEC: 245/65/17 |265/70/15
| 265/75/15
DIAM: 29.5"| 29.6"
| 30.6"
WIDTH:
9.6" | 10.4"
| 10.4"
SIDEWALL:
6.3" | 7.3"
| 7.8"
REVS/MILE:
683 |682
| 658
