C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Jan 27, 2008 9:47 am
I expect pretty good results from Bear brakes, but a few concerns I'd have about their brakes are in the photos, I don't see any outer dust seals on the pistons. Secondly, I didn't see any indication that they fit the correct piston sizes to match the vehicle's brake torque bias. Lastly, their rotors appear to be a 2-piece non-floating type. This means that as the rotor heats up, it expands, while the aluminum hat section will expand at a lower rate. This causes the rotor to cone. Though, I wouldn't be as concerned with it on a 15 inch rotor used on the street as the temperature change may be relatively low and thus, the effects of coning may be minimal. Of course, if this is only for street use, there is little concern to even need a brake upgrade. If race track use is planned, I'd be much more critical of all aspects of the brake system's design. Seemingly little things can make huge differences in performance, longevity and even brake feel/response.
