15,000 mile service
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
Jonkarn1
Car: 2008 EX35
Just brought my 2008 EX in for brake service, as the brakes were vibrating a bit and not as strong. I was told it may be covered under a service bulletin which would be great.
They recommended the 15000mi service which includes tire rot alignment oil fluids air filter, cleaning batt terminals etc. Since I changed oil 2 months ago I passed on this. I allowed them to rotate tires and align wheels. The other things I feel are unnecessary and expensive. Anyone else feel this way?
What are the necessary things to be done at 15000 without just throwing money away? By the way I have a 2008 that until 3 months ago was barely driven which is why am just doing this service now after 2 years.
mikemax99
Car: 2010 ex35 journey Aspen white
2011 STI black obsidian
Perso, I don't think the air filters are unnecessary if they are dirty but yes you can do them by yourself. Have they service they brakes under the tsb?? because brake t-up is necessary (caliper lubrication etc...). brake t-up is kind of cheap compare to caliper replacement. If your car is low in miles, like you said, your better to follow the maintenance schedule cuz a car that dosen't ride worn faster!
Jonkarn1
Car: 2008 EX35
They replaced the brakes under the TSB. Calipers pads etc.. I will try to replace air filter myself. The battery terminals are perfectly clean so I didnt feel need to have them charge me to clean them. I had them Rotate and align wheels and balance. I assume this is good enough under my lease agreements.
ANBYOND
Car: 2010 EX35
2005 GTO
Those 15k mile service and many of the other services... they are usually just inspections and minor things that you can do yourself and save a lot of $$. Most of them are not really parts/fluids or replacements of anything, just looking at things. The same service they sell you for say $300+, an independent shop would do for $100+ Those are the biggest $$ makers for the service dept.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
