that doesn't always happen. the turbine wheel isnt gonna come out as one piece and fall out the exhaust. it will shatter to bits and can very easily shoot pieces backwards and into your head. It is a definite possibility. I know of an sti that did this and ruined his head/block.RB20DETodd wrote:i was curious what boosting it at 14 could do other than rocketing the exhaust wheel out the exhaust, i have my spare rb20 turbo so im not 100% worried about the turbo, more the engine, -Todd
Based purely off calculations... I'd say he's making up to around 280-300 bhp (at the crank) since the max power of the 20 with stock cams and intake manifold comes in around 6100-6500 rpm... probably less with the stock interheater.Eikon wrote:Correct.. the Rb20 injectors are 270cc.
With your Rb25 turbo at 14 psi.. what HP to you estimate you were making? If you think you were near 300... you would have pretty well maxed your injectors and you were probably close to doing some damage.
I have also heard that you shouldn't boost a RB20 past 12 psi... but that is on the RB20 turbo.
The Rb25 turbo will make more hp than the RB20 turbo at similar boost levels. Example... Rb20 at 10 psi vs. Rb25 at 10 psi... the 25 turbo will make more power.
But, that's not to say that the RB25 turbo will handle that much more pressure.
See the following link... it's recommended that you don't take the RB25 turbo past 10 PSI. At 14psi you really risked blowing it. zerothread?id=83607
Im gessing about 230 to the wheels, it hauls ***, Carl whats a good way to wire the fans so they come on when the engine starts?sean8564 wrote:so on 14psi with a 25 turbo what kinda HP numbers are you looking at
I run a painless wiring thermo switch kit. They kick on @210 and off @180 and have there own relay and breakerrbsileighty wrote:Regardless of what you use as a trigger... run the fans themselves on their own 30 amp relay...
