145,000 miles to much to turbo??
DRFT24O
Car: 1991 240SX Fastback
91 KA24DE, compression all over 155, so you tell me. Want 300whp.
Craving4Boost
Car: 91 240sx fastback
i have 175k and am in the process of boosting...
it better be over 155psi! 155 is not too good of a condition for 300hp...i have 175psi
DRFT24O
i only cranked it a couple of times, it may go higher. how long should i crank for??
Drift Machine
Car: 1991 KA-T 240sx
Was the engine warm? Did you disconnect the injectors? Pull all the spark plugs?
240SicknessX
Car: 96 240 SE
you do not need to unplug your injectors to properly do a compression test.
while the car is running pull the fuel pump fuse, it will stall, this runs out the fuel pressure in the line and when you crank it again to test the cylinders it dosent inject fuel (raising compression #'s).
you really should have a charger hooked up to the battery on 50amp or start to keep your starter turning at the best speed possible. but if your battery is good good then you shouldnt have a problem. crank that thing until the cylinder pressure stops increasing, then purge the air and move on to the next cylinder.
you can add 1\2 cap of motor oil to the cylinder and redo the test and compare the results to measure how much air is passing by the valve seats, or rings. from a vocational book i have here, genrally speaking, more then 10psi increase with a wet (oil) test means that air is seeping past the rings. anything less usually the valve seats are to blame.
nissanfanatic
Car: 1992 Nissan 240sx SE
Pull the coil wire too. I count to five one thousand. Or just crank it over for five seconds.
jab11185
Craving4Boost wrote:i have 175k and am in the process of boosting...
i have 203k on my DE right now and before it blew up i had compression between 170-175psi on all 4 cylinders
I was still planning on turboing it with that many miles because to the compression results were still good
DRFT24O
some good info here. thanks. so safe to turbo if over 170?
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
I dont think its too much. My motor had 128k on it and ran absolutely perfect. It was still very strong, but I went ahead and put a 40k motor in mine bc it was available. Good luck and keep us posted on the progress.
Structure240sx
even numbers across are very good. 155 is a little low thought to me.
have the engine warm and throttle fully open
DRFT24O
ill check the compression again tomorrow and crank it for a bit longer.
Jookmasta
just finished turboing and i have 142K. Compression was 180 across the board and is still 180 across the board since last time i checked. I think ur compression is really the determining factor, not the mileage..........
(this is if everything else is in working order)
