14" Winter Rims
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
yyc_davis
Car: 2009 Nissan Versa SL
Hi Everyone, new to the forum - I got a lead on a set of winter tires on craigslist except they are 14". the bolt pattern from a 93 g20 will fit my versa my concern is are 14" rims going to be too small for my 2009 versa hatchback.
Any help would be appreciated.
thx
Codelicious
Car: 1989 Nissan 240SX
Don't quote me on this one but I think they will be fine. I think I have heard that the base Versa models come with 14" wheels... I could be totally wrong though.
Best thing you could do is try them before you buy them if they will let you.
NODES
Car: 2007 Nissan Versa SL (Blue)
Codelicious wrote:Don't quote me on this one but I think they will be fine. I think I have heard that the base Versa models come with 14" wheels... I could be totally wrong though.
I read on here that 14's are too small due to the brakes on the SL, do not quote me on it, just do a quick search.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
If you have the 1.8 motor, they will NOT fit. The clearance is already really tight on the stock 15" wheels. Doesn't matter if it's an S or SL. They have the same brakes. They will fit on the 1.6 true base models as those have smaller brakes and come with 14" wheels stock.
NODES
Shad0wXCalibur wrote:If you have the 1.8 motor, they will NOT fit. The clearance is already really tight on the stock 15" wheels. Doesn't matter if it's an S or SL. They have the same brakes. They will fit on the 1.6 true base models as those have smaller brakes and come with 14" wheels stock.
ah that's what it was, thanks for clearing that up.
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
Just stick with 15" wheels and get winter tires, easy said and done!
Versa357
Car: 2009 Nissan Versa 1.6 Sedan
Are you sure about that? When I look up brake specs I get the same information for both the 1.6 and 1.8.11.02 inch x0.92 disc. 9 inch drumI also noticed on versaspeed he is selling rotors and says they will fit the 1.8 and 1.6.I wouldn't think those would be smaller then stock and there isn't anything saying 1.6 owners would have to change wheel size.
Shad0wXCalibur
I'm pretty sure. Someone on this forum has tried 14" wheels before and said they didn't work. I can just look at my brakes through the alloys and tell there is no more room to go a size smaller. Not to mention you would have fat balloon tires and decreased handling. Econocars usually already have the smallest wheels that will fit over the brakes. So my conclusion is yes, the 1.6 true base Versas do have slightly smaller calipers since they come with 14"s stock.
Versa357
I knew it wouldn't handle the best but in the winter I dont think they were looking for performance.Just seems strange they would use a different caliper with same rotors.
ke30dan
i am in the hudson valley new york. i own a base 1.6 with 14" wheels. if anyone is local and wants to try to put one on their 1.8 versa, it will answer all questions.
Return to “Versa Technical Discussions”
